Adam1480
- Dołączył
- 13.05.2025
- Postów
- 15
- Punktów
- 10
Adres 5F: Elektr.informacji Plik etykiet: 8W0-035-MIB-HGS2.clb
Oznaczenie elementu: 8V1 035 652 D HW: 8V1 035 652
Komponent i/lub wersja: MU-HS-S-US 050 0235
Kodowanie: 01730101FF0A000011110001061A00232F012DC501F001044E
Kod serwisu: WSC 06335 790 00021
Zbiór danych ASAM: EV_MUHigScl6C3DELP 001011 (AU37)
ROD: EV_MUHigScl6C3DELP.rod
VCID: 382928FD22D0751AA7B-806C
Kody bledów zostaly skasowane.
Znaleziono 1 blad:
1543 - Sterownik zakodowany nieprawidłowo
U1014 00 [00001001] - -
Potwierdzony - Testowany od skasowania kodów bledów
Ramka zamrozona:
Priorytet bledu: 4
Czestosc bledu: 1
Wew.licznik bledów: 225
Przebieg: 101387 km
Data: 2025.12.29
Czas: 18:58:59
Napięcie zacisku 30: 12.1 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
Zrobiłem konwersję na ER, wszystko mi ładnie działa, lecz błędy i nie zamyka się ekran od MMI, ktoś w stanie pomóc ?
Może komuś się przyda, pamiętajcie !
Wszystkie linie oprócz FC1L49xE muszą być ręcznie ustawione na [Y] (zmień [D], [N], na [Y]) i dopiero potem uruchomić Start aktualizacji:
do tego :
Car Scanner
2D00 (14 języków):
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
280: 72755F52550072755F52550072755F525500323753BE
Pomogło wszystko jest jak należy !
Znaleziono 1 blad:
Ramka zamrozona:
Priorytet bledu: 4
Czestosc bledu: 1
Przebieg: 101387 km
Data: 2025.12.29
Czas: 18:58:59
do tego :
Car Scanner
2D00 (14 języków):
