z takimi błędami auto trafiło na warsztat. Diagnoza - uszkodzona sonda. po jej wymianie pozostał błąd dpf. |(poniżej )
Kod:
VIN: WV2ZZZ7HZFH060141 License Plate: DD
Address 01: Engine Labels: 03L-906-022-CAA.clb
Control Module Part Number: 03L 906 019 GH HW: 03L 907 309 M
Component and/or Version: R4 2,0L EDC H45 6303
Software Coding: 0119401A230400080000
Work Shop Code: WSC 02757 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019GH 003004 (VN75)
ROD: EV_ECM20TDI01103L906019FM_003.rod
VCID: 77FD8DF9CE1CD7FAF8-8022
2 Faults Found:
5188 - Diesel Particle Filter
P2463 00 [175] - Excessive Soot Accumulation
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 143798 km
Date: 2063.14.18
Time: 20:25:26
Engine speed: 871.50 /min
Normed load value: 34.1 %
Vehicle speed: 0 km/h
Coolant temperature: 85 °C
Intake air temperature: 32 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.720 V
Unlearning counter according OBD: 40
Counter for regeneration time of diesel particle filter: 0.00 s
Particle filter: kilometers since last regeneration: 292537 m
Particle filter: soot mass measured: 7.58 g
Particle filter: soot mass calculated: 40.11 g
Particle filter: differential pressure: dynamic offset: 5 hPa
5104 - Oxygen (Lambda) Sensor B1 S1
P2237 00 [237] - Pump Current Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 143798 km
Date: 2063.14.18
Time: 20:26:53
Engine speed: 862.00 /min
Normed load value: 18.8 %
Coolant temperature: 84 °C
Intake air temperature: 37 °C
Voltage terminal 30: 13.800 V
Readiness: 1 2 0 0 1
Address 01: DTCs cleared
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 143853 km
Date: 2063.14.19
Time: 12:52:19
Engine speed: 1995.00 /min
Normed load value: 55.3 %
Vehicle speed: 68 km/h
Coolant temperature: 89 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 13.960 V
Particle filter: kilometers since last regeneration: 347527 m
Particle filter: soot mass measured: 3.72 g
Particle filter: soot mass calculated: 45.54 g
Particle filter: differential pressure: dynamic offset: 4 hPa
Readiness: N/A
[/CODE]
Podejrzewam, że w związku z zawartością sadzy ponad 45g, nie można przeprowadzić wypalania ?
