ABS swieci brak reakcji na zmiane biegow
Karmag
Tomaszow Lubelski
Czesc,,
Problem polaga na tym ze jak chwile pojezdze auto wywala bledy i nie rusze do momentu jak ``troche `` ostygnie.
Silnik pracuje caly czas skrzynia at powershift.
===PCM DTC U0415:86-AF===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module 'A'
Additional Fault Symptom :)86):
- Signal Invalid
Status (-AF):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Powertrain Control Module
Freeze Frame #1:
-EVENT_TIME: 358845377 s (Fri Sep 08 11:50:56 2023) - Event time
-TOTAL_DISTANCE: 188739 km - Total Distance
-MODULE_VOLTAGE: 14.3 V - Control Module Voltage
-ESTSERUN: - Engine status - engine running
-ESTSECRK: - Engine status - engine in crank
-INCAR_TEMPERATURE: 15 °C - In car temperature
-OUTDOOR_TEMPERATURE: 15 °C - Outside temperature
-PWR_MODE_KEY: - Power Mode Key State
-PWR_MODE_QF: - Power Mode Quality Factor
-LOAD: % - Calculated Load Value
-ECT: 82 °C - Engine coolant temperature
-MAP: kPa - Manifold absolute pressure sensor
-RPM: 1/min - Engine Revolutions Per Minute
-VSS: 0.0 km/h - Vehicle Speed
-IAT: °C - Intake Air Temperature
-MAF: g/s - Mass Air Flow
-FRP: kPa - Fuel Rail Pressure
-BARO: kPa - Barometric pressure
-APP_D: % - Accelerator Pedal Position D
===END PCM DTC U0415:86-AF===
===OBDII DTC U0415-C===
Status (-43):
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===END OBDII DTC U0415-C===
===TCM DTC None===
Successful DTC reading, no error codes found
Module: Transmission Control Module
===END TCM DTC None===
===AWD DTC B2477-40===
Code: B2477 - Module Configuration Failure
Karmag
Tomaszow Lubelski
Wszystkie bledy jakie mi forscan pokazuje sa w tym logu.
Auto nawet jak nie ruszy z miejsca(nie zakreci kolami), a zlapie temperature to i tak odcina?
- Signal Invalid
Status (-AF):
Freeze Frame #1:
Status (-43):
===TCM DTC None===
Status (-40):
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: All Wheel Drive Module
Diagnostic Trouble Code details
===END AWD DTC B2477-40===
===ABS DTC C1233-A0===
Code: C1233 - Left Front Wheel Speed Sensor Input Signal Missing
Status (-A0):
- Previously Set DTC - Not Present at Time of Request
Module: Antilock braking system
The left front wheel speed sensor input signal is missing or the signal is not plausible.
The code is set normally when the speed from one sensor differs from the speed on the other three sensors. The vehicle speed must exceed 40 kph (25 mph) for this code to be set.
A fault has been reported. At some time a wheel speed signal has been out of range. The possible causes are as follows:
Damaged wheel speed sensor.
Sensor air gap too large.
The vehicle has been towed on two wheels.
A road wheel has been dynamically balanced on the vehicle while the IN2IGN iwas in position II or shortly after IN2IGN off.
The vehicle has been driven on a two wheel rolling road.
There is a short duration intermittent open circuit on the sensor wiring.
The vehicle has been accident damaged or abused (eg. rolled spun parking brake turns etc.)
The tires installed have varying outside diameters.
A wheel bearing is worn or loose.
Additional Information
The ABS lamp should be illuminated.
The ESP lamp should be illuminated.
There will be an ESP malfunction warning displayed on the driver information text panel.
===END ABS DTC C1233-A0===
===EPS DTC None===
Module: Electronic-Controlled Power Steering
===END EPS DTC None===
===IC DTC U1900-20===
Code: U1900 - CAN communication bus fault
Status (-20):
Module: Instrument Cluster
CAN Communication Bus Fault - Receive Error
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
===END IC DTC U1900-20===
===PDM DTC None===
Module: Passengers Door Control Unit
===END PDM DTC None===
===DFDM DTC None===
Module: Driver Door Control Unit
===END DFDM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===EATC DTC None===
Module: Electronic Automatic Temperature Control
===END EATC DTC None===
===RKE DTC U0101-60===
Code: U0101 - Lost Communication With The TCM
Status (-60):
Module: Remote Keyless Entry
===END RKE DTC U0101-60===
===GEM DTC None===
Module: Generic Electronic Module
===END GEM DTC None===
Wiem.
Karmag
Tomaszow Lubelski
Od jakiego czasu masz ten błąd?Przecież kod jasno mówi że sterownik silnika nie widzi poprawnie prędkości.
Blad byl od dawna auto jezdzilo normalnie trasy po 300 km. a teraz do 15min. jazdy i klops
zrobie ten czujnik i zobacze co bedzie, sęk w tym ze jak auto zimne to jedzie normalnie mimo ze czujnik caly czas nie dziala....
Karmag
Tomaszow Lubelski
ok wracam z mala aktualizacja...
Pozbylem sie bledu z czujnikiem ABS winne bylo lozysko z magnesem.
Mimo wszystko auto nadal zachowuje sie tak samo, dwa bledy ktore sa zawsze jak odetnie skrzynie i pedal gazu,
i
lucas100
nowe miasto nad pilica
Zobacz jak wygląda struktura can w tym aucie.Zobacz jak wygląda can od strony skrzyni w momencie kiedy odcina.Byc może sterownik skrzyni szlag trafia,zimne luty itp.
