Skoda Roomster ABS8.2 Long coding
BoskiRoman
Starogard Gdański
Witam potrzebuje pomocy z długim kodowaniem. Skoda Roomster 2010/11 r 1.6Tdi wysypało się kodowanie ABS 8.2 .
Vin: TMBNL25JXB5008736 Zamieszczam auto-scan
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: TMB1JC5J5B7016323 License Plate:
Mileage: 496790km-308690mi Repair Order:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 44 56
VIN: TMB1JC5J5B7016323 Mileage: 496790km-308690miles
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LK HW: 03L 906 023 LK
Component: R4 1.6l TDI H33 9978
Revision: --H33--- Serial number:
Coding: 00114016000400080000
Shop #: WSC 13765 031 00121
ASAM Dataset: EV_ECM16TDI02103L906023LK 003011
ROD: EV_ECM16TDI02103L906023LL.rod
VCID: 7AFB44E9FDDF5E9A9B-802E
1 Fault Found:
7332 - Mass Air Flow Sensor (G70)
P0103 00 [165] - Signal too High
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 496793 km
Date: 2019.10.11
Time: 00:19:08
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 9 °C
Intake air temperature: 10 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 11.520 V
Unlearning counter according OBD: 40
Engine speed: 0 /min
Vehicle speed: 255 km/h
Battery voltage: 10.4 V
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AG HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 35110 377 09999
VCID: 0305390D86151F52C8-8056
2 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 247
Mileage: 496793 km
Time Indication: 0
Date: 2014.03.03
Time: 06:05:38
Freeze Frame:
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x1213
Hex Value: 0x1490
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
03306 - Coding Not Valid
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 31
Mileage: 496793 km
Time Indication: 0
Date: 2014.03.03
Time: 06:07:41
Freeze Frame:
Hex Value: 0x0001
Hex Value: 0x0000
Hex Value: 0x1227
Hex Value: 0x148F
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 5J0 820 045 B HW: 5J0 820 045 B
Component: Climatic 12 0660
Revision: 0002S 12
VCID: 24475A9127DBF86A91-8070
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 32
Mileage: 496793 km
Time Indication: 0
Date: 2014.03.03
Time: 01:15:17
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 086 F HW: 6R7 937 086 B
Component: PQ25 BCM H10 0017
Revision: -3------ Serial number: 1002430401
Coding: 64980B3808010000002000003E0B08C00000400F600000000000
Shop #: WSC 33361 790 00085
VCID: 4683E019F1A7EA7AAF-8012
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3240
Serial number: --------------------
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3240
Coding: 020000
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 HW: 5J0 919 475
Component: PARKHILFE 4K H10 0002
Revision: --H10--- Serial number: 76241009101254
Coding: 100003
Shop #: WSC 73430 790 00085
ASAM Dataset: EV_SK25XParkiAssis2 S01002
ROD: EV_SK25XParkiAssis2.rod
VCID: 72EB6CC9A5AF26DAD3-8026
1 Fault Found:
1458176 - Internal Control Module Memory Check Sum Error
B2000 46 [008] - Calibration/parameter memory failure
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagTA0 H09 0018
Revision: -------- Serial number: 003DW00EN5JN
Coding: 004130
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 428BFC09D58FD65A83-8016
Crash sensor for side airbag: driver side:
Serial number: 3496GRB4027DKEVR7RDQ
Crash sensor for side airbag: front passenger side:
Serial number: 3506GRB402JCU8L3AS8+
1 Fault Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 496793 km
Date: 2019.10.11
Time: 00:19:12
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5J0 920 840 D HW: 5J0 920 840 D
Component: KOMBI H15 0206
Serial number: 00000000000000
Coding: 120A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2A5BB4A94DFF2E1AAB-807E
1 Fault Found:
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 32
Mileage: 496793 km
Date: 2019.10.11
Time: 01:15:16
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 086 B
Component: GW-K-CAN TP20 0017
Revision: -3------
Coding: 832200
VCID: 70EF66C1A3A314CA25-8024
1 Fault Found:
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H15 0206
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74A98D7FEE1A6B-803E
1 Fault Found:
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 496793 km
Date: 2019.10.11
Time: 01:17:47
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10110
Shop #: WSC 33361
VCID: 2F6DA5BDEA1D4B327C-807A
2 Faults Found:
49-10 - No Communications - Intermittent
01317 - Control Module in Instrument Cluster (J285)
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5J0 035 161 C HW: 5J0 035 161 C
Component: Radio-SWING 008 0031
Revision: -----05S Serial number: SKZ4Z2K1179527
Coding: 0D0004000006
VCID: 224B5C893DCFF65AE3-8076
No fault code found.
