Kod błędu 81 - Alarm antywłamaniowy system-PIN
81 Theft Warning System (DWA)
BMW Bosch DME M1.7, M1.7.1, M1.7.2, M3.1 and M3.3 Fault codes.
Engines: BMW M40, M42, M43, M50, M70, S38, S50, S70 petrol engine fault codes.
Model code: (E30 3 series, E31 8 series, E34 5 series, E36 3 series.)
1 Fuel Pump Relay or RPM Signal
2 Idle-Speed Controller
3 Injectors (4cyl-1,3; 6/8cyl-1,5; 12cyl 2,4,6 or 8,10,12)
4 Injectors (DME 3.3.1 Cyl 4,6)
5 Injectors (DME 3.3.1 Cyl 3,5)
6 Injectors- General
7 VANOS Relay or Injector cyl6 (DME 1.7.2)
8 "CHECK ENGINE" Light Failure
12 TPS or Lambda Sensor (M3.3.1)
13 Lambda Probe
15 Knock Sensor 1 (DME 1.7/DME 3.1)or Ignition Fault (DME 1.7.2)
16 Ignition System or Cam/Crank Position Sensor
17 Cam Position Sensor
18 DISA Valve (DME 1.7.2)
19 Electric Fan Output Stage
20 Cruise Control
22 Ignition Fault Cyl 7
23 Ignition Fault Cyl 4 or 6
24 Ignition Fault Cyl 4 or 6
25 Ignition Fault Cyl 1 or 5
26 Voltage Supply
29 Idle Speed Controller
31 Injector on Cyl 3 or 5
32 Injectors (4cyl 2/4; 6cyl 2/6; 8cyl 8/2; 12cyl 1,3,5 or 7,9,11)
33 Injector on Cyl 1 or 3 35 Injector on Cyl 2
36 EVAP Canister Valve
37 Lambda Heater Relay
38 Lambda Heater Relay
41 Air Flow Sensor
42 Speed Signal or Knock Sensor 2 (DME 1.7.x or 3.3.1)
46 Electric Fan
48 AirCon Compressor Shut Off Relay
49 Injector on Cyl 2
50 Ignition Fault on Cyl 1 or 3
51 Ignition Fault on Cyl 2 or 8
52 Ignition Fault on Cyl 5 or 3
54 Voltage Supply
55 Ignition (Final Stage)
62 Signal (EML)
63 Torque Converter Lockup Clutch
64 EGS/DME Connection Error
65 AirCon Compressor
66 Theft Warning System (DWA)
67 Crank Position Sensor or Knock Sensor 4 (DME 3.3)
68 Knock Sensor 3
69 Knock Sensor 2
70 Lambda Sensor (DME 1.7.x or 3.1) or Knock Sensor 1
73 Vehicle Speed Signal (VSS) or TPS
76 Idle Speed Setting - CO Adjustor
77 Intake Air Temperature Sensor
78 Coolant Temperature Sensor
82 MSR Engine Torque Regulation or Air Con Compressor (1.7.2)
83 ASC (EML)
85 Air Con Compressor Relay
100 Amplifier 1 in DME Control Unit
101 Amplifier 2 in DME Control Unit
150 Knock Sensor 1
151 Knock Sensor 2
152 Knock Control
153 Knock Control Voltage
200 DME Control Unit
201 Lambda Regulation
202 Control unit
203 Ignition system or Lambda Sensor
204 Idle Speed (EML)
205 Ignition Timing Intervention
206 Knock Control Test Pulse/Control Modules
207 Knock Control Regulated Voltage
210 CAN Interface
220 EWS 2 Immobilisation
252 EVAP Canister Valve
255 Control Unit -Internal error
333 Control Unit -Internal error
