FORD MUSTANG problem z szybami i lusterkami
RDM
FORD MUSTANG 2017 rok 5.0 USA
przestały działać szyby drzwi i lusterka , prawe i lewe
potrzebowałbym schematy instalacji drzwi kierowcy i schemat instalacji pomiędzy drzwiami kierowcy ,a BCM-em
przydałby się również schemat BCM i skrzynek bezpieczników
tak od razu z grubej rury?
sprawdziłeś bezpieczniki na początek?
Assignment of the fuses in the Passenger compartment (2017)
Amp RatingProtected components
110ADemand lamps.
27.5 APower mirror memory module.
320ADriver console unlock.
4Not used.
520ASubwoofer amplifier.
6Not used.
7Not used.
8Not used.
9Not used.
10Not used.
11Not used.
127.5AClimate control module.
137.5AGateway module. Steering column control module. Instrument cluster.
14Not used.
1510AGateway module.
1615ADecklid release.
175ANot used (spare).
185AIntrusion sensor module.
197.5APassenger airbag deactivation indicator.
20Not used.
215AIn-vehicle temperature and humidity sensor.
225AOccupant classification system module.
2310ASwitches. Power windows. Rear-view mirror.
2420ACentral lock unlock.
2530AMagneride.
2630ARight-hand front-window motor.
2730AAmplifier.
2820AAuxiliary body module.
2930ALeft-hand rear-window power.
3030ARight-hand rear-window power.
31Not used.
3210ARemote keyless entry. Multi-function display. SYNC. Global positioning system module. Gauges.
3320AAudio head unit.
3430ARun-start bus.
355ARestraints control module.
3615AAuxiliary body module.
3720APower distribution box run-start bus.
30ANot used (spare).
Assignment of the fuses in the Power distribution box (2017)
1Not used.
2Not used.
3Not used.
4Not used.
550A*Automatic brake system pump.
650A*Body control module.
760A*Body control module.
850A*Body control module.
940A*Rear window defroster.
1040A*Blower motor.
1130 A**Left-hand front window.
1230 A**Driver seat.
1330 A**Passenger seat.
1430 A**Climate-controlled seat module.
1520A**Convertible top motor.
16Not used.
1720A**Convertible top motor.
18Not used.
1920A***Steering column lock relay.
2010A***Brake on-off switch.
2120A***Horn.
2210A***Powertrain control module relay.
2310A***Air conditioning clutch.
2430 A**Voltage quality module.
25Not used.
2625A**Windshield wiper motor.
27Not used.
2830 A**Automatic brake system valve.
2930 A**Electronic fan 1.
3030 A**Starter motor solenoid.
3140A**Electronic fan 3.
3210A***Latch relay coil.
3320A***Left-hand high-intensity discharge headlamps.
3415A***Exhaust valves.
3520A***Right-hand high-intensity discharge headlamps.
3610A***Alt sense.
37Not used.
3820A***Vehicle power 1.
39Not used.
4020A***Vehicle power 2.
4115A***Fuel injectors.
4215A***Vehicle power 3.
43Not used.
4415A***Vehicle power 4.
4430A***Ignition coils (GT350 only).
45Not used.
4620A**Differential pump.
47Not used.
4830A**Fuel pump #2.
4930A**Fuel pump.
50Steering column lock relay.
51Not used.
52Horn relay.
5320A**Cigar lighter.
5420A**Auxiliary power point.
5525A**Electronic fan 2.
56Not used.
57Air conditioning clutch relay.
58Not used.
59Exhaust valves relay.
605A***Powertrain control module.
61Not used.
625A***Anti-lock brakes run-start switch.
63Not used.
645A***Electronic power assist steering.
65Not used.
665A***Blind spot information system. Rear view camera. Air conditioning compressor relay coils.
67Not used.
6810A***Headlamp leveling switch.
69Auxiliary power point relay.
7010A***Heated exterior mirrors.
71Not used.
725A***Rain sensor module.
73Not used.
745A***Mass air flow sensor.
75Not used.
76Rear window defroster relay.
77Electronic cooling fan 2 relay.
78Left-hand high-intensity discharge headlamp relay (export).
79Right-hand high-intensity-discharge headlamp relay (export).
80Windshield wiper relay.
81Starter motor solenoid relay.
82Powertrain control module relay.
83Not used.
84Not used.
85Not used.
86Not used.
87Not used.
88Not used.
89Electronic fan 1 relay.
90Differential pump relay.
91Electronic fan 3 relay.
92Blower motor relay.
93Fuel pump #2 relay.
94Fuel pump relay.
* J-case fuses.
** M-case fuses.
*** Micro fuses.
RDM
tak bezpieczniki OK
Wymieniłem pin w kostce drzwi lewych na słupku ( zielonka w środku ) :) poza tym została połowa grubości pina
Poza tym sprawdzone pozostałe kable drzwi
Auto było już grzebane przez kogoś wcześniej i nie wygląda to ciekawie
dlatego potrzebuje schematy aby sprawdzić połączenie z BCM-em
szyba kierowcy została otworzona normalnie po przyjeździe auta na lawecie
powodem wizyty u nas spalony silnik rozrusznika i tak naprawdę nie wiadomo z jakiego powodu po wymianie rozrusznika i odpaleniu auta szyby już nie można podnieść i lusterka też nie działają
aaa, czyli odpinałeś akumulator. bo nie uwierzę, że jesteś takim partyzantem i robiłeś to na podłączonym.
chyba trzeba było przyuczyć szyby
Gdzies jakieś musialo isc zwarcie..elektryka w samochodzie to taki wyrok boski nigdy niewiesz kiedy nastąpi
RDM
Tak aku był odpięty , a szyb nie da się przyuczyć bo nie działają
nawet po podłączeniu kompa nie widzi drzwi lewych
Podobne tematy
