w202 kody błędów- wyjaśnienie
przemekzn
Witam, podłączyłem ostatnio pod kompa Mercedesa w202 97r. 1.8 używałem programu carsoft, wyrzuciło mi trochę błędów, miałbym taką prośbę aby ktoś podesłał kody błędów byłbym bardzo wdzięczny lub wytłumaczenie tych błędów.
Actual Error's:
3 HFM-SFI, PEC engine coolant temperature sensor : open circuit.
Measure the temperature sensor.
Reference values: 20řC = 3,5V 50řC = 2,3V 100řC = 0,8V
Verify also the resistance.
By IGNITION=OFF : 20řC = 2500 Ohm - 50řC = 830 Ohm - 100řC = 185 Ohm.
4 HFM-SFI, PEC engine coolant temperature sensor : implausible.
Reference values: 20řC = 3,5V 50řC = 2,3V 100řC = 0,8V_
6 Intake air temperature sensor : short circuit.
Reference values: 10řC = 3,2V 50řC = 1,2V 80řC = 0,5V
By IGNITION=OFF : 20řC = 6060 Ohm - 50řC = 1760 Ohm - 100řC = 620 Ohm.
12 Idle speed contact : implausibly large.
Only with EA or CC. (1) Without EA or CC. (2)
Idle speed contact at idle speed control actuator, air mass implausibly large. Verify idle speed contact :
(1) Idle speed pos. : < 3 V, Accelerator depressed : > 10 V.
(2) Potententiometer voltage : idle speed < 4,8 V, Accel. depressed > 5,5 V
13 Idle speed contact : loose contact.
Idle speed contact at idle speed control actuator,loose contact. Verify idle speed contact :
(1) Idle speed pos. : < 3 V, Accelerator depressed : > 10 V._
14 Throttle valve actual value potentiometer : implausibly high.
Throttle valve actual value potentiometer in idle speed control actuator : implausibly high. While IGNITION=ON :
Verify potentiometer, voltage decreases continuously up to full throttle position. Idle speed = > 4 V, full throttle = < 1 V.!!! Not with EA or CC !!!
22 CC/EA signals emergency running mode.
Unmetered air, throttle valve jamming.
Cruise control or electronic throttle to emergency running.
23 Oxygen sensor : voltage too large.
!!! Only with TWC. !!!
At coolant temp. > 80řC run engine for at least 2 min. at idle speed. Verify voltage oxygen sensor signal : -0,2V/1V.
Verify also the oxygen sensor cable if insulation is > 20 KOhm,
and sensor heating voltage : 11-14 V, and current consumption : 0,6-3,4A.
24 Oxygen sensor : too cold or open circuit._
Verify also the oxygen sensor cable if insulation is > 20 KOhm, and sensor heating voltage : 11-14 V, and current consumption : 0,6-3,4A.
30 Oxygen sensor heater of oxygen sensor : current too large.
At coolant temp. > 80řC run engine for at least 2 min. at idle speed. Verify oxygen sensor heater actuation. (Voltage = 11V-14V.)
Verify also the current consumption : 0,6-3,4 A.
31 Oxygen sensor heater of oxygen sensor : short circuit.
32 Oxygen sensor heater of oxygen sensor downstream of TWC faulty.
-> Current too small. !!! Only USA, except model 124 !!!
ENGINE : IDLING,
Verify oxygen sensor heather actuation. ( Voltage = 11V-14V.)
38 Fuel injection valve Cylinder 1 : open circuit/short cir. to ground.
Verify actuation and injection time.
temp = 20C (when starting)-> injection time = 8 ms.
temp = 80řC (idling)-> injection time = 3-5 ms.
temp = 80řC (throttle blipped)-> injection time = 17 ms.
Verify also engine coolant temp. and intake air temp. sensors, O2 probe.
39 Fuel injection valve Cylinder 2 : short circuit to positive.
Verify actuation and injection time.temp = 20C (when starting)-> injection time = 8 ms.temp = 80řC (idling)-> injection time = 3-5 ms. temp = 80řC (throttle blipped) -> injection time = 17 ms._Verify also engine coolant temp. and intake air temp. sensors, O2 probe.
40 Fuel injection valve Cylinder 2 : open circuit/short cir. to ground.
46 Fuel injection valve Cylinder 5 : open circuit/short cir. to ground.
Verify also engine coolant temp. and intake air temp. sensors.
47 Fuel injection valve Cylinder 6 : short circuit to positive.
48 Fuel injection valve Cylinder 6 : open circuit/short cir. to ground.
54 Self-adaptation upper part throttle : too lean.
Verify : unmetered air, fuel injection valves, diaphragm pressure regulator, wear to motor.
!!! With TWC !!!
61 Ignition output stage 3 or ignition coil for cylinder 1 : fails.
Verify : 1) dwell time for ignition coil BY IGNITION = 20-100 ms.
and IDLE SPEED = 2-4 msec.
2) primary voltage of ignition coil for cyl. 2 and 5.(200-350V)
3) ignition voltage of ignition coil for cyl. 2 and 5. (8-20 KV)
4) spark plugs.
5) quiescent current cut-off.
62 Ignition output stage 3 or ignition coil for cylinder 6 : fails.
4) spark plugs.
59 Ignition output stage 2 or ignition coil for cylinder 3 or 4: fails.
4) spark plugs. 5) quiescent current cut-off.
60 Ignition output stage 2 or ignition coil for amperage : not reached.
4) spark plugs.
64 Crankshaft position sensor signal : not recognised/implausible. Verify crankshaft position sensor.
Segments or solenoid at starter ring gear.
Starter = OPERATE -> voltage > 0,4V A.C.
Starter = IDLING -> voltage > 1V A.C.
70 Engine speed signal TN(output) : short circuit to ground.
Verify TN engine speed signal (output).
ENGINE=IDELING : 5-7,5 V.
71 Engine speed signal TN(output) : short circuit to positive.
72 Vehicle speed signal : not recognised.
Verify ABS control module.
Verify wiring from ABS control module to HFM-SFI control module.
Verify also rear axle speed sensor._
77 CO potentiometer short circuit to positive.
!!! Without TWC except model 210. !!!
Verify - CO potentiometer. Voltage = 0,2-4,7V (IGNITION=ON).
- resistance = 0-1000 Ohm (IGNITION=OFF).
- cable connection and cables.
79 Knock sensors 1 signal : open circuit.
Verify the knock sensors.
80 Knock sensors 2 signal : open circuit.
86 Purge control valve : open circuit/short cir. to ground
Verify purge control valve : actuation.
By engine at operating temp. and idling the purge control valve
must be felt to pulse after about 1 min.
Verify also the current consumption.
90 Camshaft timing actuator : open circuit/short circuit to ground.
Verify timing actuator current consumption.
Engine start and rev. up to about 3000 rpm. Current briefly approx. 1,5 then 1 A. Verify also the resistance : 4-8 Ohm.
Verify also the mechanical operation. (mechanical camshaft adjustment)
91 EGR switchover valve : short circuit to +12V.
!!! Only J and USA. !!!
Verify EGR switchover valve vacuum control.
By ENGINE=IDLING, Coolant temp. > 60C and blip throttle :
voltage = 11-14 V.
Do also a mechanical check of the exhaust gas recirculation valve.
92 EGR switchover valve : open circuit/short circuit to ground.
voltage = 11-14 V.
98 Fault in CAN communication from ASR control module.
Verify module, and replace if necessary.
Internal Resistance : 115-125 Ohm.
116 Fault in CAN communication from IRCL control module.
!!! AS of 12/94. !!!
102 TWC thermocouple : temperature too large.
!!!Only J. !!!
Verify TWC thermocouple voltage.
ENGINE=START, Coolant temp. = 80řC, RUN engine at 3000 rpm for 2 min. Katalysatortemp. 400-600řC :
Voltage should increasing during test up to 30 mV.
103 TWC thermocouple : temperature too small.
!!! Only J. !!!
104 Safety fuel cut-off from electronic accelerator or CC activated.
!!! Only with EC or CC !!!
except USA J, 202, 210 USA.
Verify fuel cut-off control from EA actuator, CC actuator.
IGNITION=ON -> voltage jumps : 2,2-11V.
108 Relay of oxygen sensor heater downstream of TWC : faulty.
Short circuit to +12V.
Only USA, except model 124/210.
Verify relay actuation voltage.
ENGINE=IDELING : 11-14V
Verify also the current consumption : 0,1-0,3 A.
109 Relay of oxygen sensor heater downstream of TWC : faulty.
Open circuit/short circuit to ground.
!!! Only USA, except model 124/210. !!!
115 Incorrect control module coding bytes from.
!!! As of 01/94. !!!
Code control unit, replace control unit if necessary.
8 Intake air temperature sensor loose contact.
Measure the temperature sensor. Reference values: 10řC = 3,2V 50řC = 1,2V 80řC = 0,5V
Verify also the plug connection of the control unit.
113 HFM-SFI control module : is not coded.
Code control unit.
16 Throttle valve actual value potentiometer : loose contact.
Throttle valve actual value potentiometer in idle speed control actuator : loose contact. While IGNITION=ON :
- Single diagnosis completed !
przemekzn
a nie ma kodów błędów do mercedesa?
tak odpala, jeździ, jak jest zimny po przełączeniu na gaz falują obroty delikatnie (800-1200) po nagrzaniu jest ok. a drugi problem to gdy wciska się gaz w podłogę / lub gwałtownie się skręci kierownicą to tak jak by któryś cylinder odcina i samochód wtedy traci moc aż do zgaśnięcia i odpalenia go ponownie wtedy jest już wszystko ok aż do kolejnego gwałtownego ruchu. (taka sama reakcja na gazie czy benzynie)
przemekzn
Te błędy pojawiły się po skasowaniu i ponownym odpaleniu silnika (wcześniej było ich jeszcze więcej)
olmar
norwegia
daj sobie spokoj z kabelkiem za 50zl ,,, skrzynia automat ? jak tak to sprawdz czy czasami modul silnika nie jest pelny od oleju ,lub dostaje sie olej po przewodach od regulator faz rozrzadu ,,,do sprawdzenia zasilania i masy
,, instalacja gazowa niezle miesza ,,potrzebna wizyta u gazera ,,,co to za instalacja???
kupiles merca niezla mina wspulczuje
przemekzn
mercedes w rodzinie od ok 6 lat, nikt nie dbał, teraz chcą ją podreperować (ponad pół roku stała bo była dziura w misce) nigdy nie była podłączana pod komputer, został kupiony kabel żeby sprawdzić czy są jakieś błędy, ogólnie to pali i jeździ ale są problemy takie jak wyżej opisałem
suse1
Olkusz
kabelki za 5 dych schodzą jak ciepłe bułeczki :D
a potem taki przyjeżdża i prawi morały co i gdzie cza zrobić wymienić ;)
resztę na forach wyczyta i tak zejdzie pół roku a potem przestaje się przejmoować i jeździ aż padnie całkiem :D
olmar
norwegia
w tym przypadku to star diagnose i bystry gaziarz
