Cześć, Świeci się abs, ESP i czerwony wykrzyknik Brakes.
Audi A4 b7 2.5tdi V6 BDG
Poniżej zapis z kompa:
Sunday,26,March,2023,13:22:06:00009
VCDS Version: Release 20.4.2 Running on Windows 7 x64
www.Ross-Tech.com
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Control Module Part Number: 8E0 910 517 B HW: 8E0 614 517 AT
Component and/or Version: ESP8 front H04 0180
Software Coding: 0004359
Work Shop Code: WSC 06325 000 00000
VCID: 2643439F91E704B649-8072
3 Faults Found:
01321 - Control Module for Airbags (J234)
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 1
Fault Frequency: 20
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x00FF
Hex Value: 0xFFAC
Hex Value: 0x00FF
01314 - Engine Control Module
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 8
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4702
Hex Value: 0x00FF
Hex Value: 0xFF92
Hex Value: 0x00FF
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 20
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x00FF
Hex Value: 0xFFAC
Hex Value: 0x00FF
Coś jest powalone w kodowaniu ?
www.Ross-Tech.com
3 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 20
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x00FF
Hex Value: 0xFFAC
Hex Value: 0x00FF
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 8
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4702
Hex Value: 0x00FF
Hex Value: 0xFF92
Hex Value: 0x00FF
P1647 - 000 -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 20
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4702
Hex Value: 0x00FF
Hex Value: 0xFFAC
Hex Value: 0x00FF
